NVidea Core calibration if my memory is right allows you to OC your core individually. Something I have never needed to play with ..... You probably wont find any difference in performance from these setting. All I was trying to do was get your core temps back. On the PII chips when you enable unlocking you loose the ability to see your core temps. After thinking about this you can reset your NVidea Core Calibration to Auto and not worry about these settings. When I was playing with my 1090T I was using an MSI FX970 GD70 board which BIOS was quiet different than yours.
Rawrzor as I stated in post #8 I think you're getting to far ahead of yourself. I feel your best bet is to put everything back to factory defaults and then read the guide I posted, which is also the guide Bassnut just posted. There is more to overclocking then just Cpu speed, understanding this will help you better understand the changes you are making. The "Unleashed Mode" on your motherboard could very well be the culprit of your instability. This is why I'd rather see you put everything back to stock and start from square one. It will be a lot easier for us to help you pin point what may be causing instability when you are overclocking manually and have an understanding of exactly what you are changing.
You could also address vdroop through the LLC option in bios. But I don't think that's the real problem and it still doesn't explain the no show core temp problem.
