This is always a confusing thing for me. I see over clocking guides online, and basically its just "pump and dump" voltage into CPU block and nothing else. At what point do you add voltage to NB/SB/CPUNB? RAM and CPU makes a ton of sense, its the others that don't.
Clarification on this would be much appreciated.
B4933, I don't know what guides and/or tutorials you have read but here is a good one and speaks to the very things you 'say' confuse you.
http://www.overclockers.com/forums/showthread.php?t=688663
Bulldozer OC Guide!
The principles are all there. Some names change from mobo/bios brand to the other but the idea is solid. Getting to know something of the architecture and nomenclature of the FX which you seem to have now on your new Fatal1ty Killer board is good for you. When a system area of the cpu is talked about it is not so easy to be lost. That link to OC Bulldozer will or should if read for what it says and not what we thought, well it will help.
Well you speak to one "large" group that dumps voltage to the cpu and then there are those like 'ninjacore' that replied to you first that don't really seem to tweak their boards for all that is there for free if you call it up.
Yes raising CPU_NB frequency and thus having need often to raise the CPU_NB can add more heat. Well with my ram overclocked beyond DDR3-2000, there is a need for my CPU_NB to be speeded up as well. So I have my ram hauling booty and raised the CPU_NB frequency over which the ram communicates and had to add some CPU_NB voltage. More heat? A little but you know what? I don't care since I have very g00d cooling. One without good cooling...well he does not need to be overclocking an 8 core FX processor much anyway. Probably cannot go fast enough to use overclocked ram or the overclocked CPU_NB.
As for these two > NB/SB < I seldom ever see any need to add voltage to them. There is a rumor of a situation where using 3 video cards in tandem can benefit from a very slight voltage increase to the NB itself, but I have NEVER seen such for myself. The SB, well I don't add voltage to it.
You need to read some of the posts where people like "trents", "johan45" and "mandrake4665" are helping peeps with the beginnings of setup for overclocking. They generally suggest this and I agree as relates to Voltages.
1. Add 0.05 to your ram voltage and most generally so if the ram is some of the 1.5Volt stuff. 0.05 will not hurt at all and back when 1.5V ram was first out most of it was 1.65V ram binned to run at 1.5V. I run my ram 0.05V over day in and day out as a hedge against ram issues.
2. They also relate that if you are going to run CPU_NB in lock-step speed wise that you up the CPU_NB to about 1.25V. No problem there Voltage wise as AMD in their won AMD FX Overclocking guide, say that 1.35V is not considered harmful to the CPU-NB. I have NEVER had to go that high. Might come a day though and nice to know what AMD susggest for a max.
3. Most of the time it is suggested that you baseline test the system for stability with a Vcore of about 1.4V and at that point the Speed would be 4.0Ghz. Running P95 for at least 20 mins with HWMonitor open in the back ground logging min/max volts and temps. Then we "know" something when a user posts up his CPUz > CPU Tab > Memory Tab > and the SPD tab along with that captured HWMonitor that was logging min/max temps/volts.
From 3 above user would increase multiplier by 0.5 and test again and so on until P95 Blend mode fails in some manner and then up the Vcore by one bios increment and retest. Continue on until the cpu voltage is too high for safe use or until the Cpu/socket temp exceeds ~70c and the Cpu Core/Package temp does not exceed ~60/62c.
Now that IS what those of us that have hung here for the few years of the FX processor life to date and have helped 100's or even 1000's with their overclocks, do with our rigs. Well that and push the pee out of our FXs and search for MORE cooling.
RGone...
