Won't matter which you use.
Adam Simmons said:“Some applications, such as games, use their own gamma values and colour system and will either incorrectly apply (even if enforced using software) or ignore the profile. To that end we won’t be using the ICC profile for the testing in our review and will simply be using the test settings above”
Actually, it might. On my HP 2311x *not positive on the model*, HDMI only displayed 1080p with an almost 1" margin across every edge of the screen, no matter what other settings I chose, be it monitor or driver/system. DVI is the only way I could get a full screen image. My suggestion is to try both. HDMI may very well work better with that monitor, or it may be like mine and prefer DVI.
That's a programming issue, not an interface issue.
Very few monitors will ever run in to what you saw. Honestly, I'd be asking HP about it.
Hm. Well, thanks for the response on that. I would like to see the source on that, or at least some experimentation proving so, but I do believe you.
Honestly, I bought the monitor at Staples because the salesperson did a very good job. I've since discovered that rarely do salespeople know what they're selling, and don't take their advice anymore. I'm sure that it's some sort of gimmick to make that particular monitor more appealing in some way.
It is actually recommended by the reviewer of that exact review to NOT use ICC profiles for gaming. This is an email regarding a discussion I was having with him,
