- Mar 7, 2005
http://www.newegg.com/Product/Product.asp?Item=N82E16820161615
WINTEC
Model 35145588-P
Type 184-Pin DDR SDRAM
Tech Spec
Capacity 512MB
Speed DDR 400 (PC 3200)
Cas Latency 3
Voltage 2.5V
ECC No
Registered/Unbuffered Unbuffered
Warranty
Manufacturer Warranty Lifetime
VS
http://www.newegg.com/Product/Product.asp?Item=N82E16820141436
Brand Kingston
Series ValueRAM
Model KVR400/512R
Tech Spec
Capacity 512MB
Cas Latency 3
Voltage 2.6V
ECC No
Heat Spreader No
Warranty
i'm seeing some good reviews for the wintec and am about to go for that unless y'all have any comments on the superiority of kingston...
WINTEC
Model 35145588-P
Tech Spec
Capacity 512MB
Cas Latency 3
Voltage 2.5V
ECC No
Warranty
VS
Brand Kingston
Series ValueRAM
Model KVR400/512R
Tech Spec
Capacity 512MB
Cas Latency 3
Voltage 2.6V
ECC No
Heat Spreader No
Warranty
