Here's some background of what I'm trying to achieve; plus my separate thread for GPU blocks & TIM.
What make/model tubing IYE offers excellent performance & resilience?
I don't care too much about how easily it bends, I don't envisage having any terribly tight turns.
Performance/resilience is paramount...
I got some 1/2" Tygon w/my kit, but I've read lotsa bad stuff about my model, + there's not enough of it anyway.
How about larger than 1/2"(13mm) ID & 3/4"(19mm) OD? e.g. 5/8"(16mm) ID & ?/?"(21mm) OD
I've also heard there's flat tubing which performs better (makes sense), perhaps I should be looking at it too?
After closely looking a what Koolance offers, below is what I must narrow-down WRT fittings/joins etc.
It's hard to tell for sure from their site, but what I've listed looks like the only suitable stuff.
That's assuming there's no better tubing dimensions than circular 1/2" ID, & 3/4" OD.
Many of their parts seem to want 16mm (5/8") OD or less...
Why's that & am I missing-out on some of their best parts by sticking with my current tubing format?
It doesn't look like there's any suitable adapters, but pretty-much every other category is covered.
Fittings, Nozzles [19mm (3/4") OD, & 13mm (1/2") ID]
Clamps:
CLM-19
http://www.koolance.com/water-cooling/product_info.php?product_id=715
Splitters:
SPL-XUFY5B
http://www.koolance.com/water-cooling/product_info.php?product_id=667
SPL-XFR3
http://www.koolance.com/water-cooling/product_info.php?product_id=791
Fittings:
NZL-DXG-V2
http://www.koolance.com/water-cooling/product_info.php?product_id=867
ADT-VL3NMM
http://www.koolance.com/water-cooling/product_info.php?product_id=1072
ADT-VL3NFF
http://www.koolance.com/water-cooling/product_info.php?product_id=1071
NZL-LXG2P
http://www.koolance.com/water-cooling/product_info.php?product_id=680
NZL-LXG1P
http://www.koolance.com/water-cooling/product_info.php?product_id=679
Nozzles/Tube -> ID: 13mm:
NZL-V13-19KG
http://www.koolance.com/water-cooling/product_info.php?product_id=746
NZL-V13-19KG2
http://www.koolance.com/water-cooling/product_info.php?product_id=747
Quick Disconnect -> ID: 13:
VL3N-M13-19S
http://www.koolance.com/water-cooling/product_info.php?product_id=885
VL3N-F13-19S
http://www.koolance.com/water-cooling/product_info.php?product_id=880
VL4N-M13-19S
http://www.koolance.com/water-cooling/product_info.php?product_id=1050
VL4N-F13-19S
http://www.koolance.com/water-cooling/product_info.php?product_id=1049
Quick Disconnect -> Threaded:
VL4N-MG
http://www.koolance.com/water-cooling/product_info.php?product_id=1048
VL4N-FG
http://www.koolance.com/water-cooling/product_info.php?product_id=2033
Valves, Fill ports
VLV-13TSPL:
http://www.koolance.com/water-cooling/product_info.php?product_id=647
VLV-BL1X2:
http://www.koolance.com/water-cooling/product_info.php?product_id=918
Obviously I probably don't need something from every category, but which categories should I favour & why?
Maybe I should get some V4LN QDC fittings for each of the 3 runs in the loop, & "call it a day" for fittings?
That's 6x tube ends, so 12x M/F QDC's; 6 of which must be screw-ins for the 6x inlets/outlets of my WB's/Rad?
These are the 2x water-blocks and 1x rad. I'll definitely use at some point:
http://www.swiftech.com/apogeext.aspx
http://www.swiftech.com/mcw82vgawaterblock.aspx
http://www.swiftech.com/MCR220-Drive-Rev2.aspx
I'll get this or some other single-slot, full-cover, GPU block too.
I'll probably also get a single-slot, universal, WB, if there's one out there.
Then maybe these items to top things off for now:
Flow Meter
INS-FM18 (is it better in any way than INS-FM17N, why's it $10 more?)
http://www.koolance.com/water-cooling/product_info.php?product_id=1170
Flow Meter and Manometer Calibration Testing: interesting read
Temp Sensor
SEN-AP005PB
http://www.koolance.com/water-cooling/product_info.php?product_id=738
Tubing Wrap -> OD: 19mm (assuming I stick with this format!)
SPR-19BK
http://www.koolance.com/water-cooling/product_info.php?product_id=560
What sort of impact will adding this stuff & the QDC fittings have on flow-rate/pressure?
I'm concerned it'll be quite appreciable, & hence I'll want to tweak/mod or replace my pump (MCP35X).
Maybe you recommend more than just the QDC fittings & other accessories I list above?
Clamps:
CLM-19
Splitters:
SPL-XUFY5B
SPL-XFR3
Fittings:
NZL-DXG-V2
ADT-VL3NMM
ADT-VL3NFF
NZL-LXG2P
NZL-LXG1P
NZL-V13-19KG
NZL-V13-19KG2
VL3N-M13-19S
VL3N-F13-19S
VL4N-M13-19S
VL4N-F13-19S
VL4N-MG
VL4N-FG
Valves, Fill ports
VLV-13TSPL:
VLV-BL1X2:
Flow Meter
Temp Sensor
SEN-AP005PB
SPR-19BK
