The only time you will need to pay attention to the OD of your tubing, is if you're buying compression fittings. If you're using barbs and worm gears it will not matter in the least.
Thanks for pointing that out....
I'm still learning the diff. fittings, their names, what they look like, & the function they perform!
2x of the 6x inlets/outlets on my blocks/rads are to be used by 4x QDC's, leaving the need for only 4x more fittings.
Which 4x (preferably koolance, but not imperative) fittings would you recommend?
I also use one set of QDC's on my benching rig so that I can easily swap my loop configuration around (cool GPU's or CPU, or a combination of both, etc...). If you're installing into a case, I don't really see the need to add the flow restriction of that many QDC's, unless you plan on swapping components on a daily/weekly basis.
The 4x (2xM & 2xF) I've downgraded to is not too bad though right?
Especially since my rad. is to be mounted on the case's lid!
Your not going to find most components that support larger then 1/2" ID.
By "components" I assume you're referring to blocks & rads?
So you're saying that most fittings able to screw into their threading, are only able to support 1/2" ID?
I believe there are fittings that can support larger than 1/2" ID, & where their threading is not compatible w/the component, an adapter can be used.
Not that I'm going to bother with that...
The second page of
this old thread shows a very basic idea I used once to get the total pressure drop across my system.<SNIP>
Excellent, thanks heaps!
Keeping this archived for when I want to work-out flow without impeding it w/a mechanical device.
You missed this final Qn:
So the remainder of my fittings (4x in total) will need to be
compressions/
clamps I guess...
Assuming I stick with 1/2" ID & 3/4" OD, which models (pref. -but not imperative- koolance) would you suggest?
Preferably Bitspower barbs and compressions.
Nicer, more colors.
Okay I'll have a look at them too! Just all compressions you reckon?
I only need 4x more fittings, given that 2x are being taken by 4x V4LN's (koolance QDC's).
You are really going to regret those QDCs.
And what makes you think that Daemonkin?
