- Dec 6, 2002
One thing I see a lot is that someone will take their existing drive configuration, change it, have to do a re-install (because they changed their boot drive config), and then attempt to compare the performance of the PC with a completely fresh install to how it was prior. Last week I was cleaning up and putting XP on an old Pentium2 450Mhz that had a 17.4g 5400rpm hard drive. I was totally blown away by the speed in which this OLD system installed XP. Only thing I could figure is that I had just installed a new CD-Rom drive and it seemed to copy files from the disc fast, which normally takes up a lot of time. After XP was installed everything including the boot times was snappy. As long as the system has a good amount of ram and a fast CD-Rom this is usually my experience with most computers I do installs regardless of other hardware. It seems kinda silly to draw conclusions based on that.
I had two 36g raptors in Raid-0 prior to going with 15k scsi. Raid-0 did seem slightly faster than just using one single drive. What seemed even faster however, was when I used both drives but ran them separate. I made one my OS/apps drive and my 2nd one just a Games drive. Having that 2nd drive there, with nothing ever asked of it other than games seemed to give a larger performance boost than when I had both drives in Raid-0. Maybe someone could do a dual raid-0 setup where one array is for their OS and another array is for their games and perhaps get the best of both worlds?
For comparison purposes, here is the HDtach from my new Fujitsu 15,000rpm SCSI drive. I can say without a doubt it is faster than any configuration I ever had my raptors in, but I’d love to get a raptor 150 or a pair of 74’s and do some real comparisons.
