I figur it's something along those lines but I hope it's a bigger one that the 80
Cause I'm pretty sure it's not a puppy!
I really couldn't understand what you were getting at with the fans so I did this.
This is how it should look. What kind of water did you get and where is it going.
You win
H80I Corsair
I think i did buy the wrong one
I was looking also to the 100 and the cooling specification where the same as the h80.Won't really make much difference Oldie, Yes the H100i would have been more suitable but to get the really high clocks you need a real water loop and a 360 rad.
The seller say the 100 has some sensors in it.
now I'm confused
The 100's rad is also twice the size with 2 fans instead of one. The salesman may have been a bit misleading. No biggie you can always exchange them if you want to. Just before you do anything you'd have to figure out if it would fit in your box. I have an Antec 1200 and had a heck of a time with mine. Looks to me like you ould put a double in the top. The second considerstion is cooling the NB and VRM section. But I think you could cover that with the side fans?
The salesman told me also that the 100 makes problems with the Dram there was not enough room for the 100.
Threw me off for a second. It was sideways. Is the fan you have on there oversizedyou can always add a second fan to the cooler itself like so.?
I don't know if it needs special clips or anything.
EDIT:C'mon Oldie you're making me dizzy!
Ok I have a meeting in an hou or so . Timing might be off. I'll be around. You gonna try that cooler any way?
