Those "grooves" help increase surface area, which will have better cooling though. It's pretty well documented that polishing a surface reduces heat transfer.
Devgoat -> I appreciate that bit, however, did you use the same TIM? Did you apply the same amount in the same way? Same ambient temps? Thats just not a proper "test" to define this honestly.
Right, it was purely anecdotal
I did use the same TIM, and used the same pattern (small blob, let the mounting pressure do the spreading).
After mounting and removing it, the spread pattern of the TIM was entirely different after lapping both surfaces, though. Before lapping, it was spotty and patchy. Afterwards, it would make a neat little evenly-spread square.
I think much of the gains I saw came from lapping the heatsink, though, as it was visibly concave and had marks all over it from the milling. Lapping the cpu probably just gave a small gain, from reducing the thickness of the heat spreader.
No, I literally mean, people take brasso or some other polishing compound to their coolers. Never understood where that started, or why people think its a good idea. I am thinking there is some language barrier to what you're trying to get at pierre, sorry . If you're saying Im misguided about what Im thinking of, no I am not. I literally mean, that there is a nominal amount of surface roughness that actually raises heat transfer capabilities of a material, with or without a thermal compound. Polishing metals to a mirror like shine is detrimental to heat transfer when all other things are considered equal (i.e. the surfaces are trued up).
But...
For example... this is just silly. Looks "cool" but sheesh...
Brasso is more or less super-fine liquid sandpaper. So I get if you get to like 2000 grit sandpaper, then use some Brasso, maybe that will help a little bit. Brasso (and most other polishing compounds) does take off metal, though.
Hmm, I am probably being too analytical then. Where is the weak link then? The whole point of TIM is not to improve metal-to-metal conductivity, its to remove air, which is an insulator.
I am a mechanical engineer and I work at a nuclear power plant, so all of this heat transfer business is pretty near and dear to my heart. On our steam generators, we actually do a scrubbing process to increase the amounts of surface roughness because when the plates are trued up they are too "finely finished" (yes, they are about as flat as you can get, laser defined leveling process, CAD controlled, pretty damn accurate haha), and polishing the surface would reduce the performance of the steam generators (more than you would expect!).
Now if there are actual untrue grooves and markings/warpings in the plates, then absolutely this is necessary, I've just never seen a plate or CPU that seemed to "need" polishing. If thats the case, then it makes a lot more sense to me. Getting an even surface is far more important than any "polishing". I'm just seeing a lot of "polished" for polished sakes out there, and it just seems really strange to me. Simple polishing will not true up anything, and sometimes will make things worse if you use a silicone based compound. Thats more of what Im speaking of.
I just think of it as metal on metal > metal on tim on metal > metal on air on metal. If you're not using a block to make sure the surface is flat, then you're probably just wasting your time, but I'm unfamilar with the process, so I'll decline to comment.
I presume in your nuclear power example that there are two factors at work. I'd bet that it's not multi-media (which is to say, it's something like a WC radiator, where it's metal on air, and nothing else), so the increased surface area beats better mating. Secondly, it wouldn't surprise me if the surface being scuffed was having oxidation removed...but not know the spec I can only guess. Feel free to tell me I'm wrong, my expertise is not mechanical.
They do something similar in HVAC as well. Look at any air conditioning system and you'll note that the condenser and evaporator coil fins are made from textured aluminum sheets instead of flat aluminum sheets. That makes the heat exchanger more restrictive but the improvement in thermal transfer is worth it. The refrigerant side of air coils are rarely textured as the poor conductivity of air is the limiting factor, but on water cooled condensers, the tubes are often twisted and textured on both sides in order to increase effective surface area.I am a mechanical engineer and I work at a nuclear power plant, so all of this heat transfer business is pretty near and dear to my heart. On our steam generators, we actually do a scrubbing process to increase the amounts of surface roughness because when the plates are trued up they are too "finely finished" (yes, they are about as flat as you can get, laser defined leveling process, CAD controlled, pretty damn accurate haha), and polishing the surface would reduce the performance of the steam generators (more than you would expect!).
