So I'm having issues with my computer. It will not POST; no beeps, only fans and lights and peripherals. The only way it will beep is if I remove the memory, then it gives me the no memory beep. Put RAM back in, nothing. This is what I've done for troubleshooting (yada yada, read toward the bottom for some interesting info).
- Reset CMOS using multiple methods (jumper, battery, hold power button).
- Insert key trick.
- Replaced CMOS battery.
- Working PSU; no change.
- Working vid card; no change.
- Remove RAM; gave error beeps.
- Remove CPU; no beeps.
- Remove vid card; no beeps.
- Remove everything but vid, cpu, and ram; no change.
- Remove CPU, leave RAM in; no beeps (leads me to believe CPU is functional among other reasons explained later).
Now here is the interesting part. It is cold out here and on the way home, I put the comp in my car which was pretty cold. Got home, plugged it in, POST! I was like WTF! Played with the BIOS and set all the defaults (was already there due to the CMOS reset but did again for good measure). Exited BIOS and rebooted; then nothing. Same as before. The cold weather had apparently done something.
So the first thing I think is, the CPU. I say ok...I test this further. I put the comp outside for a bit to cool it off and take it inside again. Turn it on, POST! So the temperature drop has confirmed my temp theory. Time to test each individual component to see what is liking the cold. Utilizing the freezer, I test each component. NOTE: condensation plays a role but I decided to take the chance.
CPU in freezer for 15 mins (cold): Pop it in, no POST. Ok not CPU.
Memory in freezer for 15 mins (cold): Pop it in, no POST. Ok, not RAM.
Motherboard without CPU and RAM in freezer for 15 mins(why the hell should this work, right?): BAM, POST!
Why in the world, why oh why would the motherboard care about it's temperature? I think a ship to ASUS may be in order. Bad mobo you think? CPU seems fine, right?
NOTE: I was getting a weird error before all this started where the harddrive would start and stop over and over when booted into windows and eventually give a blue screen of death and reboot. Eventually, it didn't boot at all.
System Specs:
Asus K8N4-E Deluxe
A64 DTR
PQI 1gig 3200
HiS x800xl
Any help is greatly appreciated,
Jeremy
- Insert key trick.
System Specs:
Asus K8N4-E Deluxe
A64 DTR
PQI 1gig 3200
HiS x800xl
Jeremy
