Hey this is pretty sweet! Thanks for posting this while includeing the minor issues that you did have, now youve got me thinkin about doing this mod My H100 runs out of steam (or turns into it? ) at around 1.425vcore
hey yea good luck guys its really easy and fun to do! I'm around for questions kinda too
very nice
pics!
for the record, the arctic silver 5 primed up nicely and temps dropped well enough for me to overclock another 200mhz.. so its 4.2ghz and the temps are better than they were when initially clocked at 4ghz.
i also got my two gigabyte 6950 1gb OC'd unlocked to 6970
i love my case, i can fit these foot long cards in here with room to put a fan at the end of them
Don't do it mate. The pump in a H100 isn't powerful enough to work except as in a closed loop.
Because its a closed loop water enters the pump/base plate at the same speed that it leaves it. Kind of similar to using a push/pull fan config on and tower heatsink, though that not really accurate either.
If you were to add air into the mix by adding a reservour that little pump will not have the power to push enough water through it.
Basically, if you want to go custom then build a custom loop. Don't mess up your H100 though. Any changes will just wreck it, the only thing you CAN change is the fans used with it.
