- Feb 23, 2011
- Toronto, Canada
[WIP]DIMASTECH NANO Build Log
Time to update the first post with recent developements.
Switched to Dimastech Nano test Bench. Most of the superficial stuff is done, lots more fine tuning with regards to cabling and whatnot to come.
Here is a link to my dropbox album with all the pictures I've taken of the build.
Instagram
DropBox
DropBox
So I recently tore apart every computer that I own. Stuffed my main rig into a Silverstone SG10. But now I've got the water cooling itch again. Air cooling, even the noctua nh-d14 i have in this sg10, just isn't satisfying.
Terrible picture of my original build:
Random Picture of my new case:
The only thing I'm going to be reusing is my bitspower fittings and my mcp35x.
Preliminary Parts List:
XSPC Raystorm Black ED with Red Faceplate.
2x XSPC GTX 670 Blocks
Swiftech MCP35x2 Pump setup
Bitspower Watertank, whatever the largest tank I can fit vertically.
Mo-ra3 420 PRO With both sides with fan grill(140x9)
4x 200mm Silent fans: I would like to run 4 fans at 600rpm to cool this entire rig while gaming. No mining or benching will be done. Actually the hope is to have no fans on at idle. And have fans turn themselves on and ramp up in speed as the water temp rises.
Aquaero 5 LT Controller
Chipset Blocks and ram blocks will also be used (for looks)
Ek Ram Block
Bitspower Black compression fittings.
Aquaero 5 LT will be mounted insude the fan grill of the mo-ra3, if it will fit. Hopefully it will, otherwise I might mount it inside the case, on top of the PSU, though it wouldn't get any airflow there.
PC Parts:
Maximus IV gene
2600k
Corsair Dominator GT 4x4gb
2 GTX 670 Reference
2xAdata 256GB SSD
Seasonic x750
Some notes. Will be sleeving with MDPC black and color-x. Heatshrinkless style. My first sleeving job so I hope I can figure it out.
I'll be covering up the PSU on the inside with either some aluminum or painted acrylic. This will also cover the front I/O cables and the res will be mounted to it.
The Three fan intakes on the side will be covered with a panel of brushed aluminum to match the front of the case.
I want to get rid of the Silverstone branding on the front of the case but I'm not sure how I'm going to do that just yet.
The top half of the side panel is going to get a smoked acrylic window surround on the inside with some white LED's or ccfl, will have to see how each looks before deciding.
Looks are the deciding factor for everything in this build. I've created a terrible MS Paint picture of my proposed tube routing, decided entirely because I think its the best looking tube routing.
With RES drawn in
With RES Cylinder transparent
I feel like this should work well. Though depending on my GPU test I may have to add something on the mosfet/ram line to increase resistance to increase flow to the GPU's. I'll see when I get there.
It's going to be a very slow build. MDPC sleeving and some tools are already ordered and on there way. But I'm also in the process of making and mATX freenas Box which I'll probably be posting up for your perusal at some point.
