It looks like its limited to 95w chips, so the op's 830 should be okRGone correct me if I am wrong but if the info in his CPUZ score is right he is running an AMD Phenom II X4 830 Processor with a Biostar N68S3B. The CPU Support list for the board doesnt show his CPU there ...... http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=517
Looks like HP trying there hand at false advertising to me, unless they managed to get hold of a specific model just for them with 2 extra MB of L3 (but I doubt it)As you said "Bassnut", that cpu is not in the list of supported cpus at the motherboard website and list of supported cpus.
I found this about that cpu. I know those white box configurators often use what is not selling. They may have tested and expect the cpu to work in the mobo they sold the cpu with ?
Obscure CPUs: AMD Phenom II X4 830 - Tuesday Oct 26, 2010
The multiplier changing is normaly caused by cool n quiet, as for the memory latency changing, I think it will be you're bios adjusting the timings to compensate for the low speed of 200mhz caused by the 60 MHz ref clock . If you change you're ref clock (CPU clock/fsb) manually in you're bios it should solve the issue of low speed computing, as now your CPU is only running at 60mhz x 14 (840 MHz) instead of 200mhz x 14 (2.8 ghz) and you're memory is only running at 60 x3.33 (200 MHz) instead of 200 x 3.33 (1333 MHz) so you're losing loads of juice. Put the ref clock to 200 (which is stock) save and reboot.There have been times when the multiplier randomly shows up at 4x instead of 14x. (the top banner)
Also the memory latency timing is changing without my input
9-9-9-24
6-6-6-15
any thoughts?
Thanks, I will try this later.
I heard that some bios updates can cause it to stay throttled down.
I didnt find any setting in bios to turn off cool n quiet.
I haven't tried to OC I'm just trying to get it to normal
