Last week I received a xeon Q3QS engineering sample from an eBay seller. It is supposed to be exactly like an e5649.
I installed it in my MSI x58 Platinum SLI board and was able to boot at default speeds, but got an 0x00000124 bluescreen. I continued to get these at almost each boot. Heat is not the issue. I had a Thermaltake Ultra 120 on the chip with proper thermal grease. CPU voltage also doesn't seem to be the issue, as I tried raising it up to .25 over stock and still got the bluescreens. Other fiddling with voltages for qpi, pll, etc did not increase stability. The only thing that made this chip stable was underclocking by multi to 2.0ghz.
I decided the chip was probably faulty and contacted the seller. He said he had run prime for 24 hours on the chip in an EVGA Classified SR2 stable, but that he had tried chips from the same batch on an Asus Sabertooth and had stability problems. His idea was that maybe consumer x58 boards are not compatible with these xeons.
Can anyone shed some light on this? I was planning on returning the CPU for an exchange, but if the new one is likely to have the same problem then I may want to ask for a refund instead.
my rig:
3x2gb OCZ DDR3-12800
Radeon HD 5870
Corsair 750w PSU
Large generic case with plenty of fans
Perc5i card and 4x1tb Seagate Sata drives
Western Digital 500gb Sata drive booting Win7 64
About the board: This board was running an i7 920 at stock speed stable for the past 2 years or so, and is now running a xeon e5440 stable. It has basically been worthless for overclocking though. I tried to bump the FSB on my i7 up to 140 and it won't boot, regardless of voltage, underclocking the memory, etc. Running a utility in Windows, I can overclock the FSB to about 142 stable, at least on the i7. I didn't try on any other CPU.
my rig:
Radeon HD 5870
Corsair 750w PSU
