Thank you both that helps a lot. I was asking because I was not able to understand some stuff related to mem voltages.
I have
2x4GB Kingston 1600mhz
2x4GB G.Skill 1600mhz
Mobo: Asrock 970M pro3
PSU: EVGA600W 80 plus 47A
VGA: MSI GTX 1050 2GB X
So I know you may ask, dude how is even possible that you are still running that mesozoic hardware in 2020. Well I know and let's say it's just a trip to the past for fun and for experimental materia.
The system works just fine when on windows, my previous "random restart" is gone as soon as I replaced my old PSU with the new EVGA one. The issue comes on power up. If I power up computer, all fans and lights will fire but I'll get no signal to monitor, then I shut down pc, power up again and it always boot fine. So I was checking xmp profile and found that kingston uses 1.650v while g.skill will use 1.500V so I believe it is not possible for this motherboard to give different voltages to different rams? can someone give light on this, so IDK how was XMP profile working then, so I just set RAM voltage manually following your advice that this will override XMP profile voltage parameters and will let everything else as it was. I went in and set ram voltage to 1.535 as it seems reasonable and now my computer can restart fine, but there is still no signal to monitor after shut down. Restart is okay, but shutdown will give first attempt no signal to monitor. Should I just keep bumping voltage just for troubleshooting issue? or just wait this weekend so I can use my old mobo which is in my signature and that never gave me any issues.
