Did you put the file in the root or is it in a folder on the USB drive? It's easier to put it in the root for the BIOS to recognize it. Make sure the file is extracted out if it came zipped (it does). It will not find it if it is still a zip file.
and you use a usb 2.0 port not a usb 3.0 port.
Try it as FAT32 (don't just try to reformat as NTFS!!!) as was suggested.Im going to try formatting again just to make sure. If it doesn't work, I've seen where sometimes i have to put it in a folder called bios. I'll try that too.
And I figured the sub-ambient temps where wrong one mere water cooling
If that doesn't work, get the Windows BIOS (the one that is .exe) and update it through Windows.
