the c70 vengeance seems like a really good case that im actually looking to get myself. it would work perfect for you imo because it is easily movable as long as you have some sort of muscle. this case is made out of steel almost entirely except the bezel and i believe the bays.
id suggest the gigabyte board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128706
it has not a single bad review and everything you seem to be lookign for with a 3 year warranty. to me i see the warranty as the companies faith in their products. 1 year does not bode well with me either.
keep in mind that it has ten fan slots but you wont be able to use one or two of them because of that full length card and general space concerns. i will most likely be getting a 240mm radiator liquid cooler for up top with some silenx fans that i have. ill also be putting a single rad aio for my video card on the bottom rad area.
intake- removing top drive bay-putting a fan there.
removing bottom intake on the drive bays and putting a single aio rad there.
exhaust- consists of my double rad and another exhaust fan(silenx 120mm aw)
the top three fans will all be silenx's and the bottom two will probably be some new noctuas.
if i can find some decent adapters ill put my hard drives in the 5.25 bays and put another noctua up front.(i only have one ssd a dvd/cd and a hdd)
you definitely do not need ten fans. the ten fans will consist of a limited number of actual configurations.
Should i be any more worried then if i set up my own custom loop?
Corsairs cx fans(i think cx) are good i have two in my case right now and theyre pretty much inaudible unless the room is silent. I think those are around the same price though. Silenx is good in my experience but ik quite a few people have problems with them apart from just the products. As for noctuas ive actually never used them myself but ik how well rated and liked they are which is why i would be willing to rely on them when i get a new case.
