hi guys,so i built my pc a while ago on a tight budget specs:i3-2100,hd radeon 6xxx series ,a 8gb set of kingston normal rams, GIGABYTE H61M, a samsung 19' 1366*768 , and a very cheap low quality power supply. and wanted to upgrade the pc starting from the gpu first since its the most expensive item and i can handle its expenses right now, ill probably upgrade the processor and buy a 1080p used monitor later on when i can afford, so ive made my mind on the GTX 1060 i have 2 options right now:
1-buy a new gtx 1060 3gb (gigabyte-galax-asus) for around 240-260$
2-buy a completely new but exported zotac mini gtx 1060 6gb for 230$ but without warranty(he told me he'll give me a one month trial warranty related to the shop but its still questionable).
saying that i still need a power supply since my current one is breaking down and doesnt even have 6or8 pin connectors, and here comes the same guy offering the gpu+a new seasonic 520w for 280$ (knowing that the 1060 8gb in my country egypt is 320$)
also is do you think the zotac mini gtx 1060 6gb is a good choice (its the cheapest as you can see)
its a pretty good deal but i am a bit afraid since i know that gpus cant be repaired only switched by a new one.
anyway this is my first post in any forum actually i figured you guys in here have the most experience , sorry for the long post , and thanks in advance.
