P4 Vid Mod Made Simple! No Wires Involved!
Hi all. thought I would toss this up for all those who have been wanting higher default voltages for their P4s but have been reluctant to do the VID Pin Mod or the Pin 7 POT Mod.
This little trick will take care of not having to do both. As you know the VID Pin Mod requires the connection of the VID puns located on the P4. This is done via the use of small thin wires twisted and gently wrapped around the pins. The pins needed to be done can be seen in the illistration below.
This method is again alright but it tends to worry ppl because the area they have to work in is very small and they are afraid of the possibility of breaking the pin.
Well lime I said, this method will do away with that worry all together because you don't even have to touch the CPU pins.
Here's how you go about it.
First you need a few items which are readily availible to everyone.
1 small straight pin
1 small tipped fiber paint bruch (supplied with next item)
1 jar of Rear Window Defogger Kit.
You may also want to have a little alcahol around to clean up with after you are done.
Next get your motherboard which you are going to install the P4 onto. Make sure it has easy access to the socket where the P4 is placed. (See pic below)
Now what you need to do is locate the pin holes in the socket which corresponds to the VID Pins on the P4. (See pin below)
Now with the fine tipped brush get some of the Rear Window Defogger Kit fluid onto the tip. Then simply put a bead of the fluid between the pin holes. Depending on how much you want your default vcore to be will depend on which pin hiles you will bridge with the fluid. After getting a good bead of fluid between the pins you wish to connect then clean your brush and then let the fluid dry for about a minute.
Then take the small staright pin and getly clean up and fluid that may seem like it has spread to far the side and look like it may touch any of the ajoining pin holes. Also gently poke the pin into each hole that you placed fluid into and plugged up the hole.(See pic below)
Once you have done that then you're done. Let the fluid finish drying before placing you cpu in. The pic below will show you what it should look like after you have finished.
I have just finished doing this to my BD7-Raid and with the 7D bios I now have all the vcore I need with no worry of the CBI. I also no longer have the Pin 7 POT Mod on the system. Now when I boot up, my vcore at default reads 1.80v. I can easily move the vdore level up or down with it working properly. The max vcore I can choose using the 7C bios for my BD7 and 7D bios for my TH7II is now 2.2v. This is with Woodies installed in both.
So with a mere 3-4 minutes of work I no longer need to use the soldering iron or make any kind of pin wraps or use the 40B bios for my TH7II or the 6H2 for the BD7. No more CBI on either system.
Ahhhhhhh. Life is good again.
Anyway. Thought this would help some ppl so there it is. If it doesn't wuite give you what you want then it only take a couple of minutes to clean up with a QTip and Alcahol.
That's it for now. Enjoy all.
Oh, BTW. With this mod I'm now able to take my funky ole 2.0ghz Woody and put it at 2.66ghz with out it giving me one beep or non boot. I is happy now.
