Yo,
Finally its here after 3 long weeks of waiting for my 1.1a celeron and GU370 from Stratton Computers to arrive here in NZ.
I put this baby in and fired it up at 1.46ghz right away and it loaded into winXP. I thought that ever thing was sweet, but I was wrong. Seem that the voltage is locked in place and I could not change it(1.475). Not only that the next time I tryed to boot nothing happened but a blank screen. Now every time I try and change any settings I have to take out the processor out, start the computer with no processor in it and then put back the 1.1 in.
There has been only a couple of time during the 50 odd times I have powered down and up again I was successfully able to change the voltage(don't ask me how I did this, im am still trying to figure this one out). Sometimes I can't even change the FSB in the BIOS, that to is staying locked at 133mhz no matter where I set to. I have reset the CMOS numberous times now. Really weird how this is all operating. BIOS posting screen reports all sorts of crazy low numbers like 699 (299x3).
At first I increased voltage at 1.55v and was able to run 3dmark at 1.5ghz, play half hour of quake3 and a few sisoft benchies. I went to work leaving it just on idle at the desktop and it had blanked out when I got home.
Today I run 1.65v then used cpuFSB and pushed it upto 1.6ghz, run a few sisoft's and it only made half way through 3dmark. MBM5 reported that the voltage was moving in between 1.65-1.60 and temp at 51 when load, sisoft had this at 56.
Just a note about that voltage drop with 3 different chips, 2 mainboards, 2 power supplys that I always get the voltage dropping -0.05 from where ever its set to.
I am only using the stock intel heat sink and now have stuck a case fan on top of it with some rubber bands to improve air flow it has drop the temp only slighty. As I understand the 1.1a has a thermal diode built into the processor. With that im using Arctic Silver 1. When running 1.6ghz @ 1.65v it was very hot to touch.
I didn't bother to try the GU370 heat sink because it looked smaller/worse than the stock intel one. Is this ture or should I use the GU370 heatsinkwith its small loud 5000rpm fan. Loud fans aint worth it.
It don't seem to like 1.46ghz because it can crash or BSOD. When its at 1.475v, and as I said the voltage does drop alittle, especailly under load. So im writing this thread at 1.26ghz to be on the safe side.
If I can get it again to go higher voltage what would be safe to take it to with my current cooling setup with out causing to much damage and getting it stable.
Heres the processor specs. I think I got a dud. :
PROD CODE: BX80530F1100256SL5ZE
MM #: 839626
FPO/BATCH #: 7220A518
VERSION #: A73066-003
PACK DATE: 06/13/02
MM #: 839626
PACK DATE: 06/13/02
