- Dec 13, 2005
- Right Here Right Now
I bow before the great networking gods once again.
Basically, I'm trying to get on 2 networks, my colleges network and then I have a router in my room that's disconnected from the schools network and the internet altogether and it has my NAS connected to it. I have an ethernet cable running from my onboard ethernet port to the schools network. I just got an Intel PCI ethernet card that's connected to my router.
When both are enabled, I can connect to the NAS and the web interface of my personal router just fine and windows is showing that yes, I'm connected to the internet through the schools network. But when I try actually connecting to the internet, through FF or anything really can't connect. When I disable the Intel PCI card so I'm just on the schools network through onboard, I can connect fine.
I had a similar problem when I was back at home. I'd have a USB wifi card connecting to the internet through one router and then connecting to my NAS through onboard ethernet and my router. Whenever I had the onboard port enabled and plugged in, I couldn't get online even with Windows showing a decent wifi connection and internet access.
Is there some setting I have to change? Does automatically Windows try to connect to the fastest connection for internet (my router has gigabit ethernet and the dorms here have 100mb)? Am I screwed?
Thanks in advance.
Thanks in advance.
