- Jan 14, 2011
http://www.evga.com/articles/00687/
124A (133A OC Mode) on the 12v rails!
1500W of continuous power delivery with 90% efficiency and exceptionally clean voltage output. What does that mean? The best stability, reliability, and overclockability, and unparalleled control. The NEX1500 supports today’s highest-end dual CPU and quad GPU systems. Push things even farther with OC Mode, which boosts the output wattage to 1650W to make the NEX1500 the highest-rated ATX power supply on the planet.
Keep that power in check with EVGA’s exclusive SuperNOVA software which allows you to monitor power supply voltage, power consumption, and efficiency. Adjust the power supply’s +12V rail for maximum overclock potential, or adjust fan speed for the quietest system possible. Even switch between single or multiple power supply rails! The power is in your hands.
Combine that with EVGA’s unique individually sleeved cabling system and the unparalleled control given by our exclusive SuperNOVA software, and you have an enthusiast power supply that simply cannot be beat.
