I have 2 32 gb sets of ram. They are both the same speed and everything the only difference is one is RGB and the other isn't.
They are trident.Z
Will they be okay if I mix them in the same system?
You can probably make them work together. You are probably not going to be able to enable xmp due to the mixed set though. You will have to manually clock these and set the voltages.
