- Mar 20, 2005
Ok so i finished my Water cooling setup and this is what im gonna stability test tonight
The rig is the one in my sig
Loosend my timings on ram to SPD (3-3-3-8) and running them 1:1 which underclocks them
Uped my CPU voltage to 1.5v and set my FSB to 250
Ive had it stable at 240 on stock voltage but wont budge a hair without some real juice
Temps seem to be 33C-35C idle and 39C-41C load
Load and stability are being tested with Dual Prime95 running
check my sig if you want more details on the WC setup.. follow link
I got a few questions for tommorow after work when i continue...
1.) If it should fail stability how much juice is it safe to give one of these 640's?
2.) Id be more than happy with 4.0... if it is stable can i expect much more from it?
3.) How come in my bios i set my voltage to 1.5v but CPU-Z shows voltage at 1.408v? Is my bios wrong or is CPU-Z wrong? CPU-Z is also showing the wrong bios version... could this be a slightly bad bios flash?
4.) any suggestions regarding anything?
