I have finally reached 4 GHz with my E8400 (rest of hardware in sig) at 445x9. I have been stress testing every FSB increment of 3 MHz with both Linx and Prime95 Blend test and at the current settings, 445x9, I successfully ran Linx for 9.5 hours using all memory and 12+ hours on prime95 Blend test with no problems what-so-ever. The problem I am having now, though, is that Dawn of War II crashes about 10 seconds into a level. I can go through the menus fine, it's just when I start a mission. At my stable settings of 436x9 I can play for longer, 1h+, before it crashes and at stock settings, 333x9, I played for a couple hours with no crash. GPU clocks have remained the same and I tried with both catalyst 9.1 and 9.3 with the same results. So I thought of the game as a third stress test and I have tried bumping up cpu vcore, cpu PLL, NB vcore, and SB vcore all individually and none of them had any effect. The last thing I tried was to keep my "stable" settings of 445x9 but turn down the multiplier to 7 and it still crashed within 10 seconds but this time I got the BSOD compared to the freezing I usually get. I am not sure if this necessarily proves anything but it may provide insight to one of you. So, does anyone have any new suggestions or have ran into a similar situation?
My P5Q-Deluxe settings are as follow:
CPU Multi: 9
FSB: 445
PCI-E: 100
FSB Strap: Auto
DRAM Freq: 891
1st Timings: 5-5-5-12-3-55-6-4
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
Ai Clock Twister: Auto
Ai Transaction Booster: Auto (LVL 14)
CPU Voltage: 1.3375
CPU GTL Voltage Reference (0/2): auto
CPU GTL Voltage Reference (1/3): Auto
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.24
DRAM Voltage: 2.1
NB Voltage: 1.16
NB GTL Reference: auto
SB Voltage: 1.1
PCIE SATA Voltage: 1.5
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew: Auto
NB Clock Skew: Auto
CPU Margin Enhancement: Optimized
Thanks
EDIT: My cpu temps are around 31 idle and 38 load
CPU Multi: 9
FSB: 445
PCI-E: 100
FSB Strap: Auto
DRAM Freq: 891
CPU Voltage: 1.3375
DRAM Voltage: 2.1
NB Voltage: 1.16
SB Voltage: 1.1
NB Clock Skew: Auto
Thanks
