- Thread Starter
- #21
It might be a power problem. Try running Prime95-LinX and 3DMark 06 or Vantage at the same time... yes at the same time in a loop if possible for about 1 hour. If it crashes well there is an issue.
That is loco! I ran the stress test cocktail for a little over an hour and had no problems. I had GPU-Z running at the same time and made a log of the temps. None if the temps seemed really high, VDDC Slave #3 did get to 89 degrees, but like I said, I had no problems including with 3DMark06's graphic tests.
I then tried DoW2 again and to my surprise, it did not crash within the first 5 seconds this time. I was able to run it for 1m46s and then it crashed. I had gpu-z running with that as well and the temps never got above what they were with the stress test cocktail. With DoW2, VDDC Slave got to 88. GPU core got to 40, DISPIO got to 41, MEMIO was 53, and SHADER was 51 for an idea of my temps. The only difference I noticed was that the stress test cocktail only got the gpu to 88% utilization while DoW2 got to 99%.
I did uninstall catalyst last night and reinstalled 9.3 but I had the same issue last night. Something has changed today, though, and now the situation has improved but it seems it is still there. I am pretty sure it is related to the GPU now, I'll try lowering the clocks even though I kept them at stock to begin with.
