Thanks. Me too.I like that mobo mount much better than using the tray.
Wanted to go 2" but ran out of room.You only used 3/4" steel tubing for the motherboard tray? Christ man you're slacking! You sure that's strong enough to hold the motherboard?
Love it so far!
I'll have to attach the cables to the PSU before installing it.It's coming along very nicely. I do have a question for you though. How do you get to the PSU cables once everything is installed? Will you need to remove the GPU's to remove/access the PSU ports?
Haha sounds good to me.JLambeth87 natural disaster proof computer desk? Just sayin I only ask $.02 in royalties per desk!
The whole thing is overkill!It's probably a bit overkill but I think it will work well.
Lol thanks.JLambeth87,
This build is utterly ridiculous but I absolutely love it.
Adobe Suite is my editor. Dual cards for games and helps a little on renders.What is your editing software of choice? Anime?, film? Are 2 cards required for speed?
Like the beam me up scotty effect.
