That sounds better, but one question, what voltage settings do you use?
The case temp is still very high, and you should get some good case fans..
I would recommend something like 120mm in Front and 2x80 mm in the Back. Front blowing in, Back sucking out.
If the 120 mm doesn´t fit, 2x 80 mm in the Front will also be fine, but a bit louder..
