Okay I could really use some help. Two weeks ago I completed my first PC build, and everything has been working flawlessly until today. I was playing a game when the screen went this blueish-grey color (Not a BSOD, more like a fullscreen artifact) and the system shutdown and wouldn't POST into BIOS.
I assumed it was just an artifact where I had overclocked my GPU's core clock from 1000 MHz to 1125 MHz (even though I did rigorous benchmarking to ensure it was stable and I have been playing games for two weeks without problems.) But after the computer crashed the system would not POST into BIOS. My CPU, GPU, and case fans would spin and light up, but my monitor couldn't get a signal. Even my mouse and keyboard were not working.
Thankfully my motherboard has an on-board error code display which was displaying error code B2. After checking the manual it describes the error as: "Legacy Option ROM Initialization". After some research I discovered this can be caused by a faulty PCI device or slot. So I tried removing my GPU and the system posted! Well just to check that it wasn't my PCI-E gen3 slot I moved the card down to another PCI-E 16x slot and again the system would not post. So I dropped an old Radeon HD 5570 into my main gen3 slot and it works perfectly.
So does this mean that my GPU is bricked? I still have two weeks through newegg to RMA it if necessary, but I really don't want to go through that hassle if it's something that can be fixed. I have updated my BIOS but it didn't help, could the motherboard be at fault? I have read that some GPUs and motherboard firmware just don't play nice together. So I am afraid if I RMA the card for a replacement that the same thing will happen with the new card and it will be too late by then to return my motherboard to Newegg.
Can anyone please give me some advice? I would really appreciate the help. Thanks.
System Specs:
Corsair Special Edition White Graphite 600T Case
Intel i5-3570k
Gigabyte z77x-ud4h
HiS Ice-Q Radeon HD 7870 GHz Edition 2GB (OC: 1125mhz core)
Mushkin 8GB DDR3 1600MHz
Corsair Force GS 360GB SSD
Corsair CX600M 600W PSU
Windows 7 Pro 64-bit
System Specs:
Intel i5-3570k
Gigabyte z77x-ud4h
