- May 11, 2001
I have a piii700 at 933, I want to push it up to 980 or even 1ghz. I know it will run 980 at 1.75v and am assuming that it shouldn't take too much more juice to push it up even higher. At present I'm using a globalwin VOS32 lapped smooth and standard zinc thermal paste to cool. Under load my temps never reach above 37C. My question is this. To move it up to 980 or even 1gig would TEC cooling be good idea? Also, will it work with my current HS/F? I have a Anantec (probably spelt that wrong) 300w psu powering 2 WD 7200rpm drives, a creative dvd, an HP CD-r, an ATI Radeon 32, 2 120mm fans, 1 80mm fan, 1 slot fan, 1 network card, 1SB Live, a Bl'orb and the 2 fans on my HS, would my psu still have enough juice to power a 75 or 85 watt pelt? and would a 75 or 85 watt pelt be enough? Also, how risky are TEC's?
Thanx for any input.
