Well i'm looking to possibly get a water cooling system for my main rig.
* List why you want to watercool. Is it noise, preformance, abit of both, or to be the only guy in the retirement home with a watercooled A64.
Basically i want to try water cooling because my room is always hot. winter or summer and i know that it is limiting my over clocking potential. not only that it just seems like my case screams for water cooling.
* List your budget. From small to large, watercooling parts can be selected to fit your budget.
I don't really have any parts picked out yet but i'm looking to spend somewhere around $200 for the basics.
* List what tools you have or have access and how profficient you are with them.
I have a 120mm hole saw, drill and all your basic shop tools except for a dremel.
* List what kind of encloser (case) you have. And whether you are willing to cut it up.
Cheiftec Dragon. All Steel. And yes i will cut it up (i was planning on it )
* List what computer parts you have (basics like CPU, motherboard) or will be getting for your watercooled monster.
to start out all i want cooled is the cpu. Then after i get some more money and get more confortable with watercooling i want to cool my gpu.
Now for the questions.
I'm going to need a setup that won't need a lot of maintenance. Basically i want to flush it out once every 6-12 months or less. I also need to be able to transport it without fear of air bubbles/leaking. i wanted to ask the experts for the best method of doing this before i started looking.
For the radiator i was thinking a dual 120mm mounted on the inside of the case on the top. Would this be a good spot or is there a better space?
The reservoir. Can i get a relatively small one so that i don't add a lot of extra weight onto my case?
The block. Umm just one that'll perform good and doesn't cost an awful lot. as long as i stay around $200 total i'll be good.
Any other newbie advice that someone wants to throw out there is welcome as well.
Thanks!
Thanks!
