- Jan 13, 2005
ok so some one i know has found out i know something about computers and has been asking me about video cards.
first off theres no specs yet, this is a planned bulid, hes got a 700 watt PSU and a roswill thor case so far, no real substance yet he says hes looking at an 1155 socketd motherboard made by ECS, i think its this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135305
he says he wants to get 2 570's which are $250 on the low end, $280 average i was thinking 2 7850's at $220 on the low end (after MIR on that) $250 average it would be a little bit more bang for a little bit less buck.
thinking here the 7850 has 2 gigs of ram at 4800Mhz but only a 256bit bus as opposed to the 570's 1.2gigs at 3600Mhz but with a 384bit bus.
side by side theres not much difference but the 570 is supposed to be higher end last generation and the 7850 is upper lower middle class current generation. plus you know.....power usage.
any way i just noticed 7870's are down to $300, glad i didnt pay full price for mine but adding a seccond is looking like an option.
what do you guys think?
if the videocards change i did tell him a different motherboard mght be in order, i dont know much about intel stuff any more. 775 is the newest i have used
