The first thing I notice about that test is that's one cool running i7. Are those the load temperatures???
It's almost a 20degC step change across the board from the results that I saw when comparing the TRUE original with the Mega.
Looks like he used speedfan to monitor his core temperatures. Someone should really give him the link to Realtemp.
And I couldn't seem to find what the ambient air temperature was during his testing. Did anyone catch that?
Granted he's at 3.6GHz for the overclocked test and I was at 4GHz, but he pumping 1.4v to my 1.3v(bios).
Similar result pattern overall though, as he is seeing ~1deg difference between the TRUE and MEGA at full fan speed, and 3-4deg at slowest fan speed.
But whereas he's seeing a 9 and 12 deg spread through the 7-12v fan speed range, I only saw a 3 and 6 deg spread.
And whereas he's seeing a greater temperature drop through the fan speed range with the TRUE, I saw a greater drop through the fan speed range with the Mega.
Here's a screencap showing both Speedfan and RealTemp stock with no calibration or modifications.
