Can I unsolder capacitors, solder pigtails onto caps, solder pigtails back into the mobo, and basically move then 3/4 inch and lie them sideways on a mobo or is the wire/trace length of the caps important to the CPU voltage regulator circuitry?
Caps are uncomfortably bent from a heatsink upgrade on a dual Socket A mobo system i'm working on.
