- Oct 27, 2010
- Vancouver, BC
I need a little help getting my ram to be stable with a 4.05Ghz overclock.
I built this rig over a year ago now and just recently purchased a OCZ Vendetta 2 cooler. (Finally) I didn't want to be pushing up the temps with stock Intel cooler, so now is the time to start experimenting.
I went with an E8400 with the intentions to push it to 4.0Ghz. Reading so much about the overclock capabilities on this chip, I paired it with a Gigabyte EP45-UD3P.
Not knowing much about overclocking in the beginning, I have been trying to educate myself with all the information on this site and others. While at first a little confusing, most of the main concepts I think I got a handle on.
I have been able to get the E8400 to 4.05Ghz with 1.25v. Idle 37c, Load 60c. I not trying to break any records and I will be happy at 4.05. I just wanted to get some more value from this chip. I have been using OCCT as my stress test. I like the ability to be able to choose the small, med, large test and the time frame. I have been doing small 30min test just to be able to fine tune the voltage adjustments, then when it works, I up the time. 6Hrs OCCT Small is the longest so far.
So now on to the memory timings. Here is where I seem to be getting stumped. I have G Skill 8500 DDR2 1066 5-5-5-15 2GB x 4 for 8GB total. When I run at 4.05Ghz, I can put the ram to 1:1 @ 900 5-6-6-17 or 5:6 @ 1080 5-7-7-18. I have the Dram up to 2.1v. With the RAM at 1:1 @ 900 the OCCT medium test will get me about 15mins, then reboot. With the RAM at 5:6 @ 1080 the OCCT medium test usually just fails.
Here is the Question;
How can I overclock my RAM to be stable. It should be able to go much higher. And the mobo supports high speeds. What other adjustments need to be made in the BIOS. This is the part that still a little confusing. How do I get the RAM to play nice with the 4.05Ghz overclock.
Any advice would be greatly appreciated.
Thank You.
System
Intel E8400 @ 4.05Ghz 1.25v
Gigabyte EP45 UD3P
XFX HD 4850 XXX 1GB 650/1050 < 690/1190
OCZ Vendetta 2
Corsair TX 750
Antec 900
Thank You.
System
Gigabyte EP45 UD3P
OCZ Vendetta 2
Corsair TX 750
Antec 900
