- Nov 5, 2017
im new to overclockers an need advice
i'v got a ASRock Motherboard Micro ATX DDR3 2400 NA A88M-G/3.1 to go with this AMD
Athlon X4 880K with 125W Thermal Solution 4.0 4 Socket FM2+ AD880KXBJCSBX cpu any
advice for the best cpu/nb an HT-Link speed to get 4.5gz good an stable
i plan to a 1 360mm rad for the cpu alone with 9 fans a 1 stack on one side an a double
stack on the other side for max air flow plus 8 more on the case for exhaust
i will be adding a bigger gpu later with separate pump an rad
my current loadout is
my part list below
Cougar Vortex PWM 120 Cooling CF-V12HPB, Black
https://www.amazon.com/Cougar-Vortex-Cooling-CF-V12HPB-Black/dp/B008N323U6
____________________________________________
Aquacomputer airplex modularity system 360 mm, copper fins, one circuit, stainless steel side
panels
http://www.aquatuning.us/water-cooling/radiators/radiators-active/12386/aquacomputer-
airplex-modularity-system-360-mm-kupfer-lamellen-ein-kreislauf-edelstahl-seitenteile?c=6566
EK-Supremacy EVO BLUE Edition
https://www.ekwb.com/shop/ek-supremacy-evo-blue-edition
EK-XRES 140 Revo D5 PWM (incl.pump) - Glass
https://www.ekwb.com/shop/ek-xres-140-glass-revo-d5-pwm-incl-pump
Thermaltake Core V51 Power Cover Edition Black ATX Gaming Mid Tower Computer Case CA-1C6
-00M-1WN-02
https://www.newegg.com/Product/Product.aspx?Item=N82E16811133351&ignorebbr=1
___________________________________________________
AMD Athlon X4 880K with 125W Thermal Solution 4.0 4 Socket FM2+ AD880KXBJCSBX
to be overclocked to 4.5
2 sets of Kingston Technology HyperX FURY 16GB Kit (2 x 8GB) 1866MHz DDR3L Desktop
Memory HX318LC11FBK2/16 for a full 32gb
Gigabyte Radeon RX 550 Gaming OC 2GB Graphic Cards GV-RX550GAMINGOC-2GD
Corsair RMx Series, RM650x, 650W, Fully Modular Power Supply, 80+ Gold Certified
CORSAIR STRAFE Mechanical Gaming Keyboard - Red LED Backlit - USB Passthrough - Tactile
and Clicky - Cherry MX Blue Switch
2 - Crucial MX300 275GB SATA 2.5 Inch Internal Solid State Drive - CT275MX300SSD1
1 - Seagate 3TB BarraCuda SATA 6Gb/s 64MB Cache 3.5-Inch Internal Hard Drive
(ST3000DM008)
ASUS Computer International Direct Blu-Ray Writer BW-16D1HT
3 - SilverStone PWM Fan Hub System Cables, Black (CPF04)
1 - Anker 10 Port 60W Data Hub with 7 USB 3.0 Ports and 3 PowerIQ Charging Ports for
Macbook, Mac Pro / mini, iMac, XPS, Surface Pro, iPhone 7, 6s Plus, iPad Air 2, Galaxy Series,
Mobile HDD, and More
IO Crest 3.5 Inch Bay 4 Port Hub USB 3.0 with Fast Charging Port (SY-HUB20134)[/FONT]
my part list below
panels
-00M-1WN-02
(ST3000DM008)
