Hi everyone,
I'm looking for advice on upgrading my pc. It would be great if you could tell me what orader I should ge the parts and recommended specific manufacturer etc for each. You have a very nice website and forum and all seem to know what you are talking about so I thought I would post a message and see if anybody could give me a hand. I built this PC myself 2 years ago with the aid of a friend, I didn't really know what I was doing and have been learning as I go, I have made some mistakes selecting parts origonally but I have upgraded some the past few monts such as video card (should have spent more money) cooling, Power supply and memory. Before I start, I think this is a hardware issue, I have tried doing some tricks but maybe I am missing something, turned off vsync, 75hertz refresh rate etc.
PC Specs
Motherboard
ECS Elite Group P4S5A/DX. 533Mhz FSB, 4XAGP, socket 478. max memory speed is PC2700. Info Here my model isn't the + version but I don't notice any difference from mine in the link
CPU
Intel Pentium 4 1.9Ghz 400Mhz FSB
Memory
Ultra (company name) 1 stick of 512mb DDR PC2700
Video Card
XFX Geforce 4 Ti4200 128mb 4XAGP
CD-RW
LG 32X10X40
Power Supply/Cooling
Thermaltake 420w Pure Power silent dual fan PSU
two Thermaltake SmartFan II Temperature sensitive case fans (1 exhaust, 1 intake
Thermaltake Spark 7+ CPU cooler, manually controlled
under normal load and CPU cooler on max, I get 31C, under load, 41 so there is room for overclock, which I cannot do with this motherboard (I think)
Monitor
Daytek 17" .25
aaalright I think that's everything. Here is what I know so far and my situation:
In 3dmark 2001 se I get 8400 3Dmarks3DMark Compare Link Here which I think is way below par and way below where I want to be for both that magic number and my FPS in games are lower than I would like them to be. I have tried overclocking my video card up to 300/553 (if I remember properly) with no problems but would like to run it at 280/540 just ot be safe (numbers might not be correct as I can't remember and don't overclock anymore). This made an increase of less than 1 Frame per second in my games and I think 40 extra 3dMarks. This leads me to believe the Motherboard is the bottleneck. Another reason I believe this is from a review from 3DGameMan when he use a P4 2.66Ghz, a Geforce4 Ti4600 and he only achieved 10,xxx using my motherboard. any thoughts here? There are no options to increase voltage or any kind of overclocking in the Bios. There is one pagepage where you can choose a memory and FSB speed, it can be set to 133/xxx (xxx is your RAM spd), instead of 100/xxx. my Ram speed is set ot 166Mhz however, when I change the FSB speed (I think that's what it is can't remember right now) to anything other than 100, say 133, the computer will not Boot up at all, the power must be shut off by the power supply and I have to set it back to 100. because of no voltage options etc. and it not letting me increase FSB makes me want to get a new mobo. what is your thoughts here, and why can't I increase the FSB?
I know my video card is getting dated now and I should have spent more cash on it at the time (does having 4X AGP on the card really make much difference?) but I still think my system is performing far less than it should be for the card memory and CPU. is that correct?
been thinking about getting a new mobo that can support faster memory say, PC3200 and get 512mb of that and it has to have hyper threading, 800mhz FSB and 8XAGP. can you recommend how fast memory I should be purchasing for overlocking and good use into the future?
ok i'm gonna stop blabbing now I think i've told everything I can that would help you understand what i'm thinking. Just take a look at what I have said and advise me on the weak parts of my system, what is slowing me, and my mobo issue. I NEED HELP!
Thanks in advance, Steve
PC Specs
Motherboard
CPU
Memory
Video Card
CD-RW
LG 32X10X40
Monitor
Daytek 17" .25
