Fringe, any thoughts on where I should tweak? Or trents?
BTW changing the HT to 1800 helped a LOT, instead of bombing out in 10s it went about 90... And now I am experiencing a clean bsod, not just a crash.
Its known that lowering the HT Link Speed increases some stability. Its not 100% proven but in many cases people have got more stable OCs doing so. Here are my steps on how to get a stable OC.
1. Fix your ram timings. Unstable ram timings = unstable OC PERIOD!!! If you don't know your timings and ram voltage or if it's not printed on the side of the ram module, call your ram manufacturer and demand them to tell you what timings to run
You can manually do this all your self, but why bother when you can just get recommend timings. Now you can tighten and loosen the timings if you are going to OC the ram, but you can do that in a later OC chapter. For now just tackle the CPU and NB until you get a stable OC, then worry about OCing the ram later.
2. Find a sweet spot with voltage and frequency.. Up the frequency on default voltage till you crash, when you crash up the voltage by 0.25 mv or the next notch up, and continue the same process of finding your max frequency per voltage increase. Do this till you find your max.... It will take time but in the end you will find out what frequency go with what voltage level.
3. Don't worry about CPU-NB or CPU-NB Frequency... Just leave it at auto..
4. The NB is just like the Core, find the sweet spot for frequency vs. voltage. I got mine to 1.300v @ 2400MHz. You can start there and work your way around it, or you can manually find your own limit
If I made any typos, I apologize.. I really didn't feel like going back over it thoroughly
Take care and I hope this helped. I might make a video on my Youtube channel some time later explaining how to OC on the AMD platform
If you need to contact me for any OC questions ASAP, here's some of my contact information.
Skype: Amofrags
Twitter:
@Fr1nge
Steam: 360Vasiliecod
Xfire: 722vasiliegx
Just hit my up with a DM on either and I'll try to help ASAP.
