Right now I have a Gigabyte Z370P D3, which, as you may know, is one of the most basic Z370 boards. Considering this and that I have just a Cryorig H7 cooling my delidded i5-8600k, I'm actually happy to be able to reach a 4.8 Ghz overclock. This is not 100% stable, one core failed the prime95 test after about 40 minutes, but at least it doesn't crash, even when rendering video or playing games like AC Odyssey, which get all cores up to 100% at times. However, something happened to my motherboard when putting back the CPU after delidding it, and now the first PCIe slot won't work, so I have to put my GTX 1080 on the second slot, which is only runs at x4, which not only gimps the gpu, but also makes it run hotter, since the card is very close to the PSU shroud and gets worse airflow than before. The CPU was tested on a different PC with a video card on the first PCIe slot and it worked perfectly fine, so I guess it's safe to assume that it's my board that's failing. I thought that since I'll change it because of the PCIe slot, I might as well go for a motherboard that's also better suited for overclocking so I can finally achieve a 5 Ghz overclock. Of course I'll also upgrade the cooler to something like a Noctua D14 if needed.
So, after doing some research, these are my main options within my budget:
-Asus Prime Z370-A
-Asrock Z370 Extreme4
-Aorus Z370 Ultra Gaming
-Aorus Z370 Gaming 3 (can't find the 5 one where I live :/)
-Asus TUF Z370 Plus Gaming
-MSI Z370 Tomahawk
I was also wondering if I should consider a cheap Z390 board, like the MSI Z390-A PRO, but I don't know if it being Z390 means it has better overclocking capability.
I don't know much about VRMs and power phases, and I don't know where to look up that info, since it's obviously not mentioned in the manufacturers websites, so I come to you hoping you can help me choose a new motherboard.
Thank you for your time!
-Asus Prime Z370-A
-MSI Z370 Tomahawk
