- Thread Starter
- #41
Yep you're right on the mem it's x2. Are you using a manual voltage or an offset? With the hardware failure you probably need more volys.
1.25 ish volts to the cpu is not enough voltage for much more than the 4.0Ghz you reached.
RGone...
Hmm So before I overclock it anymore I would be better off installing that fan under the MOBO right?
