Do you have to run cas 9? Those are REALLY REALLY REALLY loose timings for 1300mhz... Even Chew* was running 1800+mhz on cas 7....
like i said, tts not my final tweak. was juz testing the new bios for gd70. wanna see how far it can bring my 810 on stock vcore(1.28v). so far 20% overclock but i havent tried pushing it any further yet cuz this is stable. im trying 7-7-7-21 now and its runs fine. the problem im having is, i dun wanna tighten too much because im running on 4 ram modules (1gb each) and i read somewhere that the am3 ram controller isnt stable when u have all 4 slots filled because of a bug. ill try tighten them again report back.
edit: well, like i said i cant tighten the rams any further.( slaps ownself for getting 4 modules instead of 2) tried running 6-8-6-18 and it goes into BSOD right before booting in windows. a voltage bump might do the trick, but thats not what i wanted. i wanted to try to push this rig as far as it can on stock voltages. after im sure it can run stable. then ill push it again with adjusted voltages. right now settling with 7-7-7-20 and running memtest atm.
