- Mar 16, 2001
- Lafayette, La.
I just built a system about a week ago. It is stable as a rock and it screams. But I thought maybe something was wrong with the temp sensor. Room temp about 68-70 and VIA hareware monitor show system temp @23 with left side of case off and 25 with case on. Shows cpu temp @ 2-3 degrees above system temp @ idle and never got above 36. Until today!!!!!!!!!!
Today I encoded my first DVD into MPEG-4 format (actually I am doing it right now). And the temp shot up to 47. It is bouncing between 46 & 47 but not above 47.
Here is my system:
Iwill kk266 rev1.2
1GHz (266fsb) AXIA T-bird @ 1.33GHz
256megs Crucial PC133 ram
GeForce2 MX 400 64mb
WD 30GB 7200rpm ATA100
12x Creative Labs DVDrom
Coolermaster HSF rated for T-bird 1.2GHz (until my swiftek MC462A gets here)
and stuffed it all into an Antec sx830 case
Heres my question. I heard cpu temps can be off by as much as 10 degrees? I did bend my sensor up befor I installed the cpu. Are these temps ok? or should I hold off on mpeg encoding until the swiftek arrives?
Here is my system:
Iwill kk266 rev1.2
