Hi. First time poster here.
Looking for some good solid advice on which case to get for my next rig.
I am planning on purchasing the following:
M/B: Gigabyte GA-790FXTA-UD5
CPU: AMD Phenom II X4 965 C3
HSF: Scythe Mugen 2
RAM: OCZ/Corsair haven't made up my mind which yet.
PSU: Strongly considering the Corsair HX 750w
GFX: ATi Radeon Hd 5750 or 5770 (will be looking at X-Fire in the future)
plus a SATA DVD-RW
I will be carrying HDD's over from my current system for the time being (4x SATA Raptors and 1x500GB PATA)
All that really leaves me looking for is a case.
Specifics - Not really bothered with anything fancy, has to be a midi tower (not full or mini), has to be deep enough (wide) to accommodate the Scythe Mugen comfortably and has to be deep (long) because I like lots of space, the longer the better.
I am currently running a Lian-Li (unsure of model) that weighs in at 210mm (8 1/4") wide X 495mm (19 1/2") deep X 448mm (17 5/8") tall. The internals of this case with wise are just about OK, but depth is far too short for my liking.
My tower sits on a trolley under my desk. The max dimensions this allows me are 250mm (9 15/16") wide X 560mm (22 1/16") deep (before overhang) X 595mm (23 7/16") tall.
As I said before, height is note really an issue.
I have looked at the HAF 922 and height and depth are excellent at 502mm h and 563mm d, but it is 3mm too wide
I have also considered the CM 690 which at 213mm X 482mm X 525mm is only 3mm wider than my current case, a little lower (no real issue) and 30mm longer.
Looks wise I actually prefer the CM 690.
Price wise I am looking at £60-100 GBP (will probably be similar bracket in the states, ie $60-100 USD - I know the conversion is different, but the actual numbers seem to stay about the same).
So can anyone offer some more thick, deep alternatives?
HSF: Scythe Mugen 2
plus a SATA DVD-RW
