man_utd said:Yes. Put one as master, other as slave. To do this, make sure you have a cable with a total of 3 connectors. Set the jumpers to master on one, slave on the other, and connect the cable in. Should boot fine with both drives.
WELCOME TO THE FORUMS
hibner said:On the back of the drives are the jumpers you can change. I usually just put them on "cable select". Plug your master drive into the middle plug on the cable, and the slave to the end plug.
I actually believe that changed at one point. Starting with Ultra ATA 66, the Master is on the end (because if you only have one, you want it on the end for signal quality) and the slave is in the middle. Before that, I believe it was the other way around._slh_ said:Its actually the other way around, slave is the middle connector and master is the end.
