Hi everyone - it's my 1st post after 9 years
Well, I've got a problem with my asus p5nt deluxe mainboard. I wanted to give it to my friend, but two days after I connected everything and checked if it's working, motherboard did not run.
After I switch on the PSU, the fan starts for 3-4 seconds and then stops. If I turn it on with power switch it's similar - fans run for 3-4 seconds and stop.
Is it possible to (cheap) repair it?
Well, I don't know what's the problem, but it's 4-th MB I destroyed from January . The first one was Asus a7n8x-e deluxe - same problems, I even didn't touch it it was still in the case...
The next one was msi with LGA775 socket - same problems as with ASUS.
Another one was GA-8I945GZME-RH - 2 minutes after I connected everything and started computer it turned off. The IDE cable was HOT(!) and the MB was death.
Power supplies are different in each case, the whole HW is different... The only common think is human - ME .
Let's back to P5NT. Have you got any ideas what can be wrong? There's no beeps - NOTHING. PSU tester shows right voltage (I checked it with 2 PSUs), MB debug card shows INT 19H boot attempt, and the MB is OK.
As I said I wanted to give it (with E5200 and 4 GB RAM) to my friend -student. Now I feel really bad
