- Apr 20, 2004
- JAX, Mississauna
Good effort man and good fortune to you.
RGone...
RGone...
My CPU IDLES STABLE AT about 1.7V @ 5.2GHZ stable but will over heat if I run any program Will run overnight stable at about 50C
OK after testing things up i find that my offset value is 0.068750. With that value i am getting 1.392v at idle and when i run Prime i am getting 1.416v which i want. So i run Blend test for 2hours and 8 min and it is stable. Also my temperature are "cool" enough. Here are some screenshots.
Well at my place is 4.44 am and i am very pissed of right now....My Prime ran 45 minutes with no problems and than one error occur. Damn...
So i set: Overclock Tuner: Manual, CPU Ratio 21.5, CPU & NB Voltage: Manual, CPU Manual Voltage: 1.245 ( when i start Prime, PC automatically bump up voltage to 1.296v i see that in HW Monitor)
So here are the screen shots.
As you can see i have passed many things but after 45 minutes i fail. I am very but very frustrated, i did not sleep all night and this is what i get...
Please check this out, and give me your comments about temperatures, about this one fatal error etc..
P.S After 30 minutes my temperatures did not go that crazy and i was happy, thinking that it will be stable at 4.3Ghz, but that one error destroy me
My CPU cannot run any stress test at 4.3GHZ wihout extra voltage
Like i sad before i am settled at 4.42Ghz right now until cooler time arrives. I am not going to push mu CPU at this current hot climate, 4.42Ghz will do just fine in the next month or so
Prime 95-Blend Test
Prime 95-Large FFT
And your 3 posts in a few minutes means what? The thread is nearly a month old now. If you need something...best to start your own thread. We don't pay as much attention to older threads since we know the OP is usually gone.
You telling me I am a noob at Overclocking ? Back off and prove me wrong
Ah I see now. Thought you were perhaps needing help like most do that post. But I see from your attitude that you are more like a bragging troll. Have fun since I don't care how high you clock. We mostly are into helping those that are trying to overclock and not those that have it down pat. Good luck man and have fun.
