AT7-MAX2 Northbridge HSF Removal
Mastametz
Stanwood, WA
i just got on to ask the exact same question....trying to put AS ceramique on my northbridge....then i cant get the fan off....
GREAT MINDS THINK ALIKE :)
Sonny
Senior TIFOSI
VARIANTE ASCARI
Pinch the anchors of the push pins at the back of the mobo for it to detach, so yeah remove the board from the case.
Audioaficionado
Sparkomatic Moderator
Don't use any thing other than tweezers or needle nose pliars. Once you get the spear end squeezed together, it should pull out fairly easy from the top. Be careful not to slip and scratch the mobo traces on the bottom.
