- Feb 24, 2001
Well..let me start with what I am doing right now...
Right now I have my window open, and the weather here is very cold, but i actually like it..guess cause Im used to it...anyway my window is open 24/7..and my computer is in now case at all...i plan to get one soon...well anyway..i also have a dual cooling fan on the slot a athlon...its made for 900mhz athlons but i got it for the 550 since i may upgrade later on....right now my temp is below 19 degrees all the time...and i have overclocked to 633 with overclocked pc 100 ram...see my sig for all that info...the temp will rise to 21 and at teh most it is 23, so i was thinking of...well instead of just letting the air blow in....i would channel it directly to teh processsor..and later when i get a case have it going into the case cause winter air really works good...so should i use the winter air an channel it just through the hsf on the athlon or would this be a bad idea?
