I am new to this forum but I have a question.
I have been making computers for some time now and I just built a new computer for myself but I have a problem. I have a Asus A7v333 motherboard with an Athlon XP 1900+. I have the Swifttech MCX370 HSF but MBM5 recognitizes the CPU Temp to be anywhere from 48-53. 48 when the system is idling and 53 when the system is be worked hard. These tempuratures are WAY WAY to high for my liking. I applied Artic Silver 3 just as described on there website. I even reinstalled the HSF but the problem still continues. I have the Enermax Aluminum case with 2 exhaust fans directly behind the cpu, 2 fans in my Enermax PS, one 120mm intake side fan, and one intake fan up front. I feel that my temps should be way lower than this. My Motherboard temp is 35-37 and that is good but the Cpu is way to high.
Should I apply Artic Silver a little thicker?
I have my CPU Heatsink fan blowing down on the cpu and the 120mm fan on the side blowing down on that. Is this correct?
Is the reading from MBM5 correct? Doesn't the A7V333 read the temp from the CPU and not a diode beneath the CPU?
Any suggestions are appreciatated.
Thanks,
Ryan Floyd
Thanks,
Ryan Floyd
