- Mar 3, 2005
- Jacksonville, FL
- Thread Starter
- #21
calcal said:hrmm looks complicated
so if i flash to GT bios i can definetly get 16 pieps and 6 vertex?
You can unlock the pipes with the Rivatuner without flashing but its a great chance that you will get artifacts since not enough voltage is supplied so therefore you need to flash your card to give it more Vcore just like with CPU's where you feed it more voltages if its not stable.
If this is to complicated for you or you don't have understanding how to do it then I would strongly suggest that you don't do it at all since you could damage your video card.
Its better to run at stock settings then not to run at all. Do more reading on this if you are interested but everything you need to know about flashing is provided in that guide. You just need little understanding with DOS and that's about it, everything else is smooth sailing.
